Gjac
Mar 10, 2015Explorer III
popeyemth wrote:That area needs to be dry before anything will stick to it. Abrading the surrounding area, cleaning with acetone, drilling the two stop crack holes that Teton suggested and using the ABS cement as MFL described with insure a good bond. Also if you can wrap the FG around the pipe you will eliminate any stress induced peeling of the repair. Some stress caused this to crack in the first place and it caused the PO repair to crack also. Does the tank or pipe move or vibrate?
Put blocks under the wheels on that side to raise the valve above level so it won't drip on you.
