Pirate1
Mar 10, 2015Explorer
RayJayco wrote:When does the acetone stop working? Will the paste continue to dissolve the tank?Teeton wrote:
If you do find it's a crack and you can drill small 1/8 inch hole at the ends of the crack do so.. That helps keep it from cracking... Just my 2 cents.
Yes, this is good info as it usually stops the cracks.
Most black tanks are ABS. Just put some ABS scraps in a mason jar and add some acetone (any of the 'tones actually) and let it sit for a couple of days. It will become a paste that you can cover crack and be the same strength that it originally was...
