Rvpapa
Mar 11, 2015Explorer
DaHose,
Been there and done that. Remove clamp, heat up joint with heat gun and pipe will twist right out. To install clean inner and outer real good and smear both surfaces with urethane caulking, don't use glue. Caulking will stay flexible, glue won't. Give a quick spray with water (to cure urethane) and twist together. For clamps I used a couple of T-BAR (like on a turbo boost hose.
Mine has been good so far for ten years FT.
Art.
Art.
