enblethen
Jul 06, 2014Nomad
That is either a short plastic nipple or one of those super cheaper check valves. Look at piece that you have out for small rubber O-ring looking item inside. That would be a check valve. Replace with a brass one.
Whit stuff is most likely pipe dope. Dries up!
You should be able to use an e-z out. I have a sprinkler head e-z out for removing the broken adapters.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 24, 2026
