Govcat's avatar
Govcat
Replace AC DC Converter w/panel
As a Newbie to this forum forgive me if I'm in the wrong place. I have a question if someone can help me out. I think I need to replace my Ac Dc Converter - Its an Atwood Fortron TP3 4530ss it doesn't appear to be putting out DC to charge or run anything. They don't seem to be making this anymore and it has been a bit anemic in keeping the battery charged when it did work. I run off the battery just fine on the 12V DC side and 120V on the AC side. I've been using a battery charge/maintainer to get by at the moment. The converter is integrated into the Breaker/fuse Panel. I was wondering if I could keep the Breaker panel and remove the converter from the panel. Then replace the converter with maybe another brand in a 3 stage model or something better and keep the Atwood panel. Also could I upgrade it to 55 Amps from the current 45Amps. My guess is that it should be ok but I wonder if anyone has done this or any suggestions on a solution that wouldn't break the bank here. Much appreciate any input. Thanks
