Lantley
Sep 28, 2023Nomad
wa8yxm wrote:
With any water heater the water in the pipes heater to tap/shower is room temp.
And there is your quart. the Tankless has hot water coming out the outlet within half a cup.
Go home. Turn on the shower. How long before you get hot water out of your tank type water heater?
The only disadvantage to Tankless is you have a minimum flow rate before it heats.
There is definitely a delay with tankless. A tank heater has 130º water ready to go. A tankless does not. The cooler water in the pipes is a factor for both. Tankless does not produce hot water instantaneously. It takes a few moments for tankless to produce hot water. You will notice the lag or delay with tankless in a house or RV.
That said tankless is a very bad idea for an RV.
My 10 gallon tank water heater gives me unlimited hot water. I never run out.
Having unlimited hot water via tankless is a fallacy.
You don't have unlimited supply nor do you have unlimited waste water storage.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
