GaryS1953's avatar
Aug 01, 2017
Replace old TV antenna
Hi - Our 1996 camper has the typical old batwing type antenna that raises up with a crank from the inside. I recently hooked up a new digital tv to it and could only get about 1 channel. I thought I should get at least 15 because that's about how many I could get in the house with just using rabbit ear type antenna. I figure either the antenna is COMPLETELY wrong for the new digital tvs, or I have a bad connection some place in the cable from the antenna to the inside coax connector. Any ideas on how to determine which, and any recommendations on inexpensive type replacement for it would be appreciated.
  • darsben1 wrote:
    SoundGuy wrote:
    The only thing that may be "wrong" with your antenna is that considering it's on a 21 yr old camper it may be an earlier non-amplified version, in which case you'd benefit by replacing it
    with a current model Winegard Sensar IV which does have an amplified head. In that case you'd also have to install a Winegard wall plate that will route 12 vdc to the head and power the preamp inside it. Better still, install a Winegard SensarPro which offers up to 10 db of signal amplification beyond what the head can provide.
    Could be the amplifier is off and just needs to be turned on.
    Hmm, I tend to think it is NON-amplified as Soundguy suggested, but if not, where would I find a switch to turn it on? It's certainly not by the coax connector plate.
  • SoundGuy wrote:
    The only thing that may be "wrong" with your antenna is that considering it's on a 21 yr old camper it may be an earlier non-amplified version, in which case you'd benefit by replacing it with a current model Winegard Sensar IV which does have an amplified head. In that case you'd also have to install a Winegard wall plate that will route 12 vdc to the head and power the preamp inside it. Better still, install a Winegard SensarPro which offers up to 10 db of signal amplification beyond what the head can provide.
Having RV issues? Connect with others who have been in your shoes.24,339 PostsLatest Activity: Nov 28, 2025
