joebedford's avatar
joebedford
Nomad II
Jan 10, 2016
Replace Schwintek slide roller?
Does anybody know if it's possible to get the shaft out then slide in a replacement roller?
  • newman fulltimer wrote:
    Its a spring loaded shaft just pull one side releases the other side it pops out
    They are NOT spring loaded. They have axle caps on each end. Doug
  • The roller is NOT Schwintek supplied. But, you have to pull the slide room or hyper extend the room to replace or gain access to the rollers under a Schwintek slide box. Due to the lack of clearance on this type slide mount. You CANNOT attempt to lift the slide box up like on other slide rooms. Doug
Having RV issues? Connect with others who have been in your shoes.24,195 PostsLatest Activity: Feb 07, 2025
