RVhiker's avatar
RVhiker
Replacement Awning Fabric
The Carefree awning fabric on our 2011 Jayco fifth wheel lasted about 5 years. I replaced the fabric with new material from rvawningsmart. It lasted about 5 years as well. Now I need new replacement awning fabric, again.
Our trailer is outside, usually in the sun, all the time. The fabric degrades in the area of at top of the tube. That area gets "crispy" and some of the awning material just breaks up.
Is there any awning material that will outlast 5 years when out in the sun all the time?
  • JBarca wrote:
    TurnThePage wrote:
    I'm getting ready to replace my 18 year old awning today. It lasted that long because I ran two strips of Eternabond along the top section.
    How wide a roll did you use? 4", 6" wide or wider? Two strips = how may inches covered?
    Thanks
    John
    I used two 4" strips for a total of 8". It covered the entire top half of the awning when rolled up.
    I don't know much about awnings, especially newer ones. On mine, I was able to lay the awning flat against the side of the trailer by putting the legs under the trailer. That made it easy to attach the Eternabond.
    I should note that the Eternabond eventually looked rather wrinkly but staid securely attached to the awning. Not pretty but very effective.
  • TurnThePage wrote:
    JBarca wrote:
    Thanks for posting your Eternabond solution for awnings. Further, all the wrinkly people appreciate your comment that some of us may not be pretty, but still can be very effective!
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
