B92F's avatar
B92F
Replacement for Costar Co detector
Our new to us 2007 Flagstaff came with a Costar CO detector that says replace by June 2013. The reviews on this brand don't inspire a lot of confidence for an exact replacement. Is there another brand that I should be looking at?
1 Reply
  • What is needed is a dual chamber detector that will detect CO and smoke from a slow smoldering fire such as may start in a R/V because of electrical fires and fast burning smokeless fires.
    After a lot of research and talking to Kidde, they assured me that this one would work in a home and also A RV,there is no difference.
    This is what I found.
    A Kidde KN-COSM-XTR-BA Nighthawk
    That seemed to be best suited for this kind of application.
    Like This
    They now can be bought at Home Depot, also At Amazon.
    Home Depot
    Amazon
    I suggest you read all the info and make your decision on this but I replaced the ones in my Class C with this one.They are rated for 10 years
    and most are only rated for 5,If your RV is older than 5 years old and they haven't been changed they are most likely no good. Mine needed to be replaced so this was a good deal for me, I had a hard wired one and I chucked it for the battery powered ones, they can be checked before each trip by pushing the test button in the center of the unit.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
