Coachmen63's avatar
Coachmen63
REPLACEMENT SCREEN DOOR SLIDE
I am trying to find a replacement screen door slide for our MH. I need one that is 11-11/16" high x 11-7/8" wide x 1-3/4" deep. I ordered one from Valterra not thinking about the depth and it is only 1" deep. There is a circle with the wording Phillips Ind on our existing slide, but when I search Phillips not much comes up. I also looked at Camco products and they aren't deep enough either.
Hopefully someone out in RV Land knows where I may be able to find a replacement screen door slide that has the 1-3/4" depth I need.
Thanks for any help you can provide.
  • I received my screen door slide today from Amazon and it is exactly the same size and color as the cracked one in our MH. The slide is made by Dexter and the part number on the tag is D6H 440136, Screen Door Slide - Smoke.
    Thanks for everyone's reply and hopefully if someone needs the same type of slide they will have this information.
  • I believe we have found a screen door slide with the necessary depth. The slide is made by Dexter and is model #440136. Ordered one of these from Amazon, but several other vendors have this product also. Slide is supposed to arrive on Saturday and I will follow up to let everyone know if it in fact fits our opening.
  • call some of the surplus stores - see if they can help
    I would try Bontragers (269) 483-7017
  • Looked at both PPL and Tweety's, but they only seem to have the 1" depth slides. They have Valterra and Camco, but depth is not what I need. Thanks for your reply.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
