BFL13
Oct 29, 2014Explorer II
RKW wrote:
I just realized something that might be significant to my decision. My new trailer has 12 volt heating pads on the holding tanks. I have 2 gray tanks, and of course a black tank. I have no practical experience with that aspect of the 12 volt side of life, but the spec sheets for those pads show an amperage draw of 9.9A for a small one. If there were three heating it would be a 30 amp draw. That could be a game changer as far as boondocking goes. A bigger battery bank and a bigger converter to charge the bigger battery bank might be prudent. Even hooked to shore power, a 30 amp draw for a 45 amp converter is not a good thing. The trailer also heats the tanks by blowing a portion of the furnace heat to the holding tank areas. The dealer indicated the best use for tank heaters are when you are going down the road, when the furnace should be off. Like I said, I have no experience with tank heaters or the philosophy of use of the tank heaters. I don't plan of using my trailer in weather that cold, but you never know what you may unexpectedly encounter.
Thoughts?
A friend has those. There is a switch but not marked on/off, so we used a meter to tell when it was on and marked that. Not needed unless camping well below freezing. Main danger is leaving it on accidentally. I don't think the furnace underbelly heating does very much at all for the tanks. The trunking goes by the tanks there anyway to the floor registers so it is what it is.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
