dougrainer
May 25, 2018Nomad
If you have the hose clamp at the exit fitting of the tank, the ABS insert is glued and held in place by that hose clamp. I use Sikaflex as the sealant to glue and seal the ABS fitting to the exit of the tank. The hose clamp just holds the 2 parts snug. The Sikaflex does the job. If you are talking about a rubber splice that has a hose clamp on each end, then yes, you loosen the 2 clamps and the ABS pipe pulls out. There should be no adhesive on this type fitting. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
