dougrainer
May 25, 2018Nomad
If it has the hose clamp holding the pipe to the exit fitting of the tank, you remove the hose clamp and use a LARGE Channel lock pliers and put pressure on the pipe by attempting to rotate the exit pipe back and forth. The adhesive will break loose. It is NOT a hard glue, but a soft glue. Never had one break the tank. Now, if it was an ABS tank with a glued ABS exit pipe, you cannot remove it. ABS glued tanks do not have hose clamps. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
