Vacationer04's avatar
Vacationer04
Explorer II
Dec 20, 2016
Replacing black tank knife valve Holiday Rambler Vacationer
The black knife valve on my 2004 Holiday Rambler Vacationer 36WDD does not seal tightly, and juice seeps down in the drain. It is a pull/push cable actuated unit and is way back in the wet bay out of sight. Does anybody know how it can be accessed for service or replacement? I have tried numerous methods to clean it from above through the toilet without success. I currently have a short section of old garden hose connected to the drain cap, that is equipped with a 3/4" connector, and poking down through the floor hatch. Otherwise, it will fill the drain with liquid between dumps. I had that unpleasant surprise once. I used to put 5 gals. of water in it after dumping but now keep it empty except to travel and camp.
  • Once you determine which brand it is and have the replacement in hand, the job is pretty easy. Messy but easy. Remove the belly cover to expose the valves. Remove the 4 acrews and nuts. Place a bucket under the valve. Gently pull things apart. Lift out the blade and gaskets. Liberally grease the new parts with plumbers grease. Reinstal in the reverse order. If your careful it should take no more than about an hour.
