Dakota98's avatar
Dakota98
Replacing Magnetek 6332 "Q" convertor - Any suggestions ?
It's still functioning, but ???
I understand these were very common installs by manufactures at the time the TT was built, (I purchased it used a couple of years ago).
I have also learned that it is pretty much useless for charging the coach batteries & since the TT is now 14 years old, it may be time to consider a new one. Currently, I am using my generator & a schumacher smart charger to do the job when dry camping. I would rather connect the genny to shore power hookup & do it that way.
  • wa8yxm wrote:
    I would go with the progressive Dynamics 4600 series, this is an "Upgrade" kit designed to replace the electronics in your existing converter.
    Thus it's less expensive than replacing the entire power center.
    If you wish... they sell those too. You already have the link to the store in the last post.
    NOTE: When I got my rig in 2005 I did some heavy duty research into converters.. I could not believe they put the best in my rig.. but they did.
    The "Best" actually is a fairly large selection of converters but the Progressive Dynamics units with the WIZARD (Either built in or plugged in) are very clearly on the list of "BEST" they are 3-stage plus one additional feature.. And US assembled. Good company rep as well.
    X2!
    I replaced my Magnetek with a Progressive Dynamics PD9160 and it worked great. Had the 4600-series been available, I wouldn't had to modify the old Magnetek case to take the PD9160. The 4600-series will save you all the trouble. The Progressive Dynamic units are much better converters.
  • Something like a pd9245 will work fine ... you can cut the wires to the old converter, leave the DC distribution panel in place, and wire the new converter to the DC distribution panel. Easy DIY - lots of "how to" articles using Google.
  • RoyB's avatar
    RoyB
    Explorer III
    All I did was add a PD9260C 60AMP SMART MODE 'STAND ALONE' Converter close to my 340AH Capacity battery bank.
    If you are happy with your Magnetek Power Distribution Panel with the 120VAC Circuit Breakers and 12VDC fuses then this is the best solution as stated above you do not have to rewire (reconnect) all the 120VAC and 12VDC circuits.
    The PD9260C was an easy install for us as all I had to do was add a separate 120VAC circuit drop just for the PD9260C Converter/Charger unit. It just plugs into the 120VAC Receptacle. Then I run the DC OUTPUT cables to fed both the 12VDC side of the Power Distribution Panel and the Battery Main switch I have connected to the battery terminals.
    My original install actually was using the WFCO 8900 series Power Distribution Panel with a WF8945 Converter/charger module located in the bottom compartment. My problem like most other WFCO products owners was it would never go into BOOST CHARGE MODE. I actually just flipped OFF the 120VAC breaker for the WF8945 Converter unit and left it installed. This is a now a working back-up unit for me if needed. When camping off the power grid I like to re-charge my batteries in a quick three hour generator run time so using the PD9260C works out fine for me when having my 30AMP SHORE POWER cable connected directly to my 2kw Honda Generator.
    My wiring looks like this with the PD9260C added.
    Food for thought
    Roy Ken
  • wa8yxm's avatar
    wa8yxm
    Explorer III
  • I just got one of the upgrade kits; http://www.bestconverter.com/45-Amp-Converter-Replacement-Kit_p_46.html#.U_NJFmMto3w
    and popped it in, it worked out great. Upgrades to current technology smart charger and retains all of the physical wiring and such so it's an easy install.
    Brian
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
