BFL13
May 21, 2017Explorer II
Not clear what happened. If you set 14.8 that must have been in single mode. There is no 30 minutes in single mode, only in three-stage mode. Before going to three stage mode you are supposed to set 14.6 while in single mode, so the three stages will have their proper voltages when you switch over to three stage.
If it is in three stage mode and you set 14.8 (use the voltage pot) it will screw up all the voltages, as it warns in the instructions.
However, it is also possible to have a faulty unit, and it is good they are taking it back for you. The PD 70 amper will be ok for amps with a pair of 6s too, except for doing the 14.8.
ISTR Mr Wizard on here has a PD 70 about 15 ft from his batteries and he can say what wire and voltage drop he gets.
