BFL13
May 22, 2017Explorer II
Steve92004 wrote:
I set it to 14.8 in manual mode then flipped it into auto
I tried 14.7 also and couldn't get it to hold the same bulk voltage I set in manual to hold in auto.
I'm certain that I only changed voltage while in manual
I don't know what happens if you set 14.8 instead of 14.6 per instructions before going to three stage. The three stage bulk is at 14.6 then at 20 min or later if the batts need more, it drops to 13.6.
I don't know if what you did would cause the erratic voltage you saw. The unit might have developed a fault or not. Anyway Amazon took it back so now you just need to get the PD set up.
