DrewE
May 29, 2017Explorer III
Steve92004 wrote:DrewE wrote:Steve92004 wrote:
I got 14.4v from the charger and 14.2v at the battery.
Is that good enough voltage drop?
So a 0.2V drop...at what charge current?
That was bulk mode so 70 amps?
I don't know
It's now in regular mode 13.6 and I still have that.2v difference
Bulk mode (or any mode) would just max out at 70A or thereabout, in theory, before the converter's current limiting cuts the voltage down. In practice it's not quite that precise; often they're limited as much by power as by actively limiting the current.
If the batteries were nearly charged, the 14.4V or whatever your converter puts out could only put a few amperes of charge current through the battery. If they are discharged, it could be a whole lot more current. 0.2V drop at 5A isn't great, but at 40A it would be perfectly acceptable. (This is, of course, a practical application of Ohm's law.)
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
