rvshrinker
Jul 14, 2021Explorer III
Old-Biscuit wrote:
"Alright, the old ones I removed seem to have a small more narrow male end, which is inserted into a brass adapter, which I removed ...."
Inverted flare......
Did you open the Link I posted to types of fittings?
Scroll down and look/read about #3
Did you crack the regulator by overtightening??
yes i did look at the link and yes I think I have #3, BUT it seems like the little brass ?adapter that goes on the regulator is now 1. on the old pigtails I removed and 2. integrated in a single piece with the new pigtails I bought.
I don’t believe the regulator is cracked. how would I know? One of the pigtail’s rubber is cracked, so I decided to replace both. I doubt that’s where it’s leaking, but I really don’t know. It just seems like I’ve stuggled with this even with the prior (original, from 2017) pigtails that cracked after 18 months, again I don’t think the cracking is where the leak is, but it’s a sign of aging and maybe a poor quality product, and it seems the propane tends to leak out even when there is no drain on it. The water bottle test doesn’t reveal any obvious leaks/bubbles.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
