rvshrinker's avatar
rvshrinker
Explorer III
Jul 14, 2021
replacing pigtails on propane tanks
I thought this would be so obvious and simple but as usual I run into all kinds of questions.
First I found out that there are ‘two kinds’ of connectors. The one I am replacing has a thread on the male end. This is what I have on the new one as well. Is this necessarily the right one, or are there more than 1 kind with a threaded male end?
Second, is there supposed to be a small washer inside the fitting? There is none on my regulator.
Third, I read different things on line: you must use Teflon tape, definitely do not use Teflon tape, you don’t need anything, or you should use LocTIte of some kind. What is the actually correct answer?
Fourth, Do I just tighten as much as possible? Could I overtighten/strip something?
Ugh. nothing is as simple as it looks to me.
  • Yellow gas pipe tape is just fine for npt threads. Not sure where that wives tale came from.
    Or pipe dope. TAke your pick. Heck electrical tape will work in a pinch.
    Thread is generally 1/4” male flare or 1/4” mpt. Just replaced one on our 2017. Fwiw the great camping world didn’t have the right one. Should have just gone to the hardware store in the first place.
  • rvshrinker wrote:
    what is the RIGHT direction?
    The correct way should wrap the tape around as you are turning in the direction of tightening the male fitting. You will be Turning to the right as you have a right hand thread.
    Hold item so threaded end is to your right....
    Then start wrap on threads AWAY from you
  • Old-Biscuit wrote:
    Yours could be NPT or Inverted Flare (check which in the LINK above)
    If old hoses screw directly into REG body then NPT
    If old hoses screw into a brass adapter on REG then Inverted Flare
    Yellow Gas Tape on NPT...not on Inverted Flare
    Tighten until you feel good resistance ....
    No washers used.
    My first TT was used, and the Community College Plumbing / Certified Master Plumber had installed a new water heater.
    Propane line (flare fitting), not only was loose enough to start a fire, but even better, pipe dope spread on the flare fitting.
