rvshrinker's avatar
rvshrinker
Explorer III
Jul 14, 2021
replacing pigtails on propane tanks
I thought this would be so obvious and simple but as usual I run into all kinds of questions.
First I found out that there are ‘two kinds’ of connectors. The one I am replacing has a thread on the male end. This is what I have on the new one as well. Is this necessarily the right one, or are there more than 1 kind with a threaded male end?
Second, is there supposed to be a small washer inside the fitting? There is none on my regulator.
Third, I read different things on line: you must use Teflon tape, definitely do not use Teflon tape, you don’t need anything, or you should use LocTIte of some kind. What is the actually correct answer?
Fourth, Do I just tighten as much as possible? Could I overtighten/strip something?
Ugh. nothing is as simple as it looks to me.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
