ford_truck_guy's avatar
Mar 12, 2019
replacing slide out wiper seal
I need to replace one of my slide out wiper seals. I am going to do it myself, so I was wondering what I may be in store for before getting into it...
This is the wiper seal that needs replacing - wiper seal
It has adhesive tape on 1 side...Can I assume that once I remove the bulb seal ( which I also have new ) I will find a few, or many screws holding the wiper in place?
I ASSUME that I just need to move the slide out to about 1/2 way to do the work?
  • You need to check this place out:
    https://www.steelerubber.com/
    They have everything for the RV
  • My wipers are individual, and both are stapled on. I only have a bulb seal, that slides on the outside wiper fitting. My bulb seal has a screw in each end. Like you are thinking, I suspect yours would have to be better fastened, than just the sticky tape. Possibly staples?
    Jerry
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
