pyro383's avatar
pyro383
Replacing the Male End of the RV Power Cord
I am needing to replace the male end of the shore power cord for my rv as the previous one had melted a bit at one of the connectors. My dilemma is to replace the male end with a replacement adapter made by Camco (not weather tight) of which I would add silicone around the openings or to replace the full length cord. Cost is $13 vs $45.
Second part, would be to buy a new replacement cord and then splice to the existing and wrap to make weather tight so that I would have 50 or more feet.
So what have you done or what would you do?
  • Get the plug replacement with the handle!
    Makes connecting and unconnecting a breeze. Don't know why the darn manufactures don't make this type of plug standard equipment.
    The reason plugs melt is loose connections which results in arching that blackens the blades on the plug.
    If your blades on the plug are not shiny copper your plugs will start to melt.
    I clean the plug blades with a simple emery board people use to file their nails. Haven't had a plug start melting in years since I started routinely sanding the blades to keep them clean.
    Comes in both 30amp and 50amp
    And yes this size plug replacement will fit in the box where the power cord is stored.
  • newman fulltimer wrote:
    buy a plug end at home delot 15 bucks and are built alot better
    That is what I have done several times and agree while not weather proof it's decent quality and generally the male end is protected by the pedestal cover. If the male end is to be outside like in an extension situation then put the connection into a cheap plastic box to protect the whole connection.
    Not sure if you can get a decent weather proof replacement male plug, but I doubt it's going to be cheap if you can.
    Larry
  • i also got fed up with stuffing the cored in the hole and installed a twist connector there. Think it was a marico.
    That hole is nothing but a highway for the mice anyway...
