Bill_Satellite
Apr 22, 2018Explorer II
BigCanoe wrote:
Hi!
I have a 2008 Outlook 31C by Winnebago. It has a Voyager camera system that is monochrome. The monitor is mounted on the cab ceiling. The model number on the monitor is AOM562. It connects to the camera cable buy a square 4 pin connector. I cant find a model on the camera but it is also Voyager. I am wondering if I can replace this system easily with a color system without having to run a new cable?
How can I tell if the monitor is color or monochrome only? Same for the camera? Will this cable be plug and play for another Voyager system? Any assistance appreciated!
I replaced a B&W setup with color and it's really of no benefit. If you current setup is working you may be disappointed with the results considering the money spent. If you do want to change then the folks at RVCams.com are the ones who will put you on the right path.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
