Canadian_Rainbi's avatar
May 23, 2017
Replacing Xantrex Prosine 2,0 Recommendations
The third Prosine 2.0 inverterd/charger has died.
Very little room near batteries. SEE PIC
since then in electric bay below the charger is the SC 2030 solar controler and shunt for the Trimetric 2030 monitor.
Need +/- 100A charging and easy to set charge parameters. (4 X 6V GS, 480 AH total)
2KW PSW
Could go separate charger and transfer switch but where to put them?
Recommendations?
  • OP- my friend sent me a picture of his install. It's too close to see the shelf where your Prosine is so I don't know if it exists, but the Magnum is bolted to the right wall, it appears above the lowest point of your ATS, so you wouldn't lose the floor space
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Interested thread as I bypassed my Prosine 2 days ago, Will be pulling it out and opening the case next week (I am trained as an electronics tech) to see if perhaps it is something simple)
    ANyone know the address(es) of the person (People) who service these things?
    I know there are a few out there. Been posted in the past but I did not take notes.. I really like the way it used to work.
  • There are a handful of people that attempt to work on these and guess where they get their parts? Blown units. I spent several hours calling all over the country but most these guys told me they essentially shotgun the units. I'll keep the Magnum..
    Perhaps the question should be who has had theirs fixed vs. junking
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    pianotuna wrote:
    Hi,
    I believe KJINTF does inverter repairs.
    Ok, who is KJINTF? Another member here?
    I do not think Xantrex authorized repair will touch it.
  • Hi wa8yxm,
    Yes. His home base is Montana. He is always grateful to receive "dead" inverters.
  • pianotuna wrote:
    Hi wa8yxm,
    For the parts.. :)
  • I don't know about the INVERTER
    But I sent him two dead converters
    One was toast, the other he repaired,
    IIRC he said they go to other people that need them, for the cost of any additional parts
    I'm quite sure he reuses any parts as possible from other converters
