BFL13
Jan 08, 2020Explorer II
MDKMDK wrote:
Yes, they are. And you can mount them upside down if you want. Try that with your "wets". :B
Guess what happens if you forget to recharge them to 0.5a/100AH at 14.x volts until amps taper that low. (see that guide and the other brands' guides, same thing.) You need an ammeter and a charger that will hold 14.x volts for as long as needed to get that done, which many chargers/converters can't do.
Also AGMs can be mounted sideways but not upside down.
