BFL13
Jan 08, 2020Explorer II
MDKMDK wrote:BFL13 wrote:MDKMDK wrote:
Yes, they are. And you can mount them upside down if you want. Try that with your "wets". :B
Guess what happens if you forget to recharge them to 0.5a/100AH at 14.x volts until amps taper that low. (see that guide and the other brands' guides, same thing.) You need an ammeter and a charger that will hold 14.x volts for as long as needed to get that done, which many chargers/converters can't do.
Also AGMs can be mounted sideways but not upside down.
Lighten up a little. :C
And please, stop micromanaging other people's batteries. It helps no one.
How do you know they can't be mounted upside down? Have you ever tried it? :E
Scroll down to where it says, "Except upside down"
http://www.wegosolar.com/products.php?product=SKR%252d125AGM-Stark-AGM-12V-Solar-Battery-Sealed-125A
Also read para 3.9 here, which even says if on their sides, only the long way, not up-ended.
https://www.trojanbattery.com/pdf/TrojanBattery_UsersGuide.pdf
