RV-1_2n-FUN's avatar
RV-1_2n-FUN
Requesting solution from knowledgeable RV.NET collective
Need to replace 2yo T-105s due to my neglect and wondering if 2-12V 24DC in parallel are a wiser less expensive choice since not using MH dry-
camping?
https://www.walmart.com/ip/EverStart-Lead-Acid-Marine-RV-Battery-Group-24DC/180350522
TIA for expert opinions as always
  • If you hook up 2 12V to create a 24V circuit you will blow up everything 12V in your coach. Please DO NOT DO THIS!
    You certainly could do 2 12V batteries wired in parallel to maintain a 12V output and increase the amp hours. Compare the amp hours of the 2 6V wired in series to the amp hours of your 2 batteries wired in parallel to compare the 2 options.
    2 6V of 100 amp hours = 100 amp hours at 12V
    2 12V of 100 amp hours = 200 amp hours at 12V
  • As you are planning to parallel a pair of 12V jars.
    Your plan will provide far less available power than you had before.
    I suggest that you start by looking at Sams or Costco for 6V golf cart batteries to replace the T-105s.
    Then, go and by a good 4 stage converter charger and take good care of these.
    Matt
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
