- Bill_SatelliteExplorer IIIf you hook up 2 12V to create a 24V circuit you will blow up everything 12V in your coach. Please DO NOT DO THIS!
You certainly could do 2 12V batteries wired in parallel to maintain a 12V output and increase the amp hours. Compare the amp hours of the 2 6V wired in series to the amp hours of your 2 batteries wired in parallel to compare the 2 options.
2 6V of 100 amp hours = 100 amp hours at 12V
2 12V of 100 amp hours = 200 amp hours at 12V - Matt_ColieExplorer IIAs you are planning to parallel a pair of 12V jars.
Your plan will provide far less available power than you had before.
I suggest that you start by looking at Sams or Costco for 6V golf cart batteries to replace the T-105s.
Then, go and by a good 4 stage converter charger and take good care of these.
Matt
