kowbra
Aug 25, 2020Explorer
ncognet0 wrote:
Thank you, i found out today the batteries are only waranteed for 5 years. then it's at least 7k to replace them. my luck they would last 5 years and one day.
I am looking at this package also... well, there sure is some good information and some misinformation on this thread, that's for sure.
The batteries are unique -both for size (255ah) and for the built in charge heaters. They are made by Dragonfly, the parent of Battleborn. I read good things in general about the brand and their business practices. It does surprise me the warranty is only 5 years; I will see if I can confirm that as I thought it was 10 years.
As to value; well each must decide. But, if you think this is just a bunch of solar panels and a couple of lithium batteries that any DIY can throw together... I think a little more research would reveal it is far more than that.
Running the whole coach, including one AC never mind both, is not trivial and was not possible a few years ago. Neither was the level of power management at the level provided here.
I would not feel comfortable doing a DIY installation of this scale and getting it all right, and I've done a couple of solar installs on prior units.
Also, add the cost and weight of some of the other suggested solutions, especially a combination of solar, lithium and an onboard generator. When I did that math, it was very close to the selling price of the Super Solar package.
One thing not noted above is how many jugs of propane needed to run dual ACs; many built in generators will go through a 40lb jug in 8 hours or less when loaded. So, let's not pretend the issue is as black and white as some make it out to be. Heavy use of the factory AC units while boondocking requires a lot of energy, and all energy comes at a cost... dollars to buy, dollars to maintain, dollars to run, etc. Solar wins on some of those and loses on others (different but the same with generators)
IMHO and YMMV, of course.
As for me, I'm nervous being an early adopter, but strongly considering it...
Brad
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
