BFL13
Oct 21, 2017Explorer II
BTDT, only with smaller fridges, so scale up for your estimates.
3.2 cu ft 120v fridge pulled about 4.5 DC amps via inverter running about 2/3 the time. So that is-- 4.5 x 24 x 67/100 = 73AH a day. That is no joke when you are off grid, solar or not. Bigger 120v fridge, say 100AH a day? (Not always the case that bigger cu ft = more draw)
So just for the fridge to stay above 50% SOC on the batts you need 200AH of battery bank, no solar, recharge every day. Solar, however much, can extend that by however much. ( Solar is just a way to extend the time between generator/charger recharging events.)
So you still need to run the rest of the rig meanwhile, so you need more batteries. Minimum about the equivalent of four 6s at 450AH.
BTW a similar size small absorption fridge that can run on propane, but running on 120v pulls more like 14 amps DC instead of that 4.5 amps. So that is a good indication of the reduced DC draw on inverter of a res fridge same size.
BUT that reduced amount is still a big problem if you are off grid and the sun won't come out. Now you must have a generator and charger to keep going, or be forced to shut down the fridge if you expect the furnace to keep you warm. It all turns into a big hassle. You need the weatherman to keep the solar going, but it turns out --he is not your friend!!!! :(
Lesson learned! If going off grid, have a propane fridge. You want to enjoy Rving , not having it be a nail-biter about the fridge.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
