Canadian_Rainbi's avatar
Dec 19, 2015
Residential fridge replacement for Norcold LRIM
I know I saw on here perhaps a year or so ago mention of a residential fridge that was a good fit for the Norcold 1201 LRIM space. I have done a bunch of searches and can't find it. I thought I had made a note of it and can't find where I put the note.
I am trying to prepare ahead of time for the death of my now 14 year old Norcold. Checking fridge specs--current draw, dimensions etc, planning extra solar, charger, inverter etc. Oh yea, and a recommended fridge :h
And if by chance anyone had done one on a 32' Itasca Horizon with the fridge in the slide. . .
Thanks
  • Look around, there are still some 197s around, but you'll have to really look for them. It's a great fridge..the replacement model is RF18HFENBSR...it's a tad taller @ 71" but still doable...Dennis
    Samsung Install
    Samsung Install
    Thanks for that. I have saved your blog link. I will be very usefull.
    What is the height of the 197? Ours is in the slide so overall height may be a problem. I don't think 71" will work. Probably won't know for sure until we remover the Norcold. :E
  • I am looking too. Look in your manual and it will give the dimensions of the cutout for your current refer. Since mine is in a slide out as well, height will be a problem. Mine is elevated about 7 inches but I do not know what is in that enclosed space under it as there is no access to it.
    63 1/4 X 32 11/64 X 24 is the opening given in the the installation manual @ zero clearance. Measuring from the top to bottom of the black plastic trim is 65 inches. Floor to top is 69 3/4 but the has to be I would guess a 3/4 inch floor under that. I'll try to measure from the outside.
  • Depending how big and how efficient your new fridge will be, you may not have to get real zealous with more solar. I run a small dorm fridge (not efficient) with just one 235W module and 300AH of battery banks.
    I would think that running a newer fridge with the 134a compressor won't require a solar upgrade as you have enough charging to run the refer and the battery capacity for a few cloudy days.
    I searched Norcold 1201 from over a year ago.. found some stuff. Not sure if you did that. I hope by 'note' you don't mean writing on paper. :E
  • MEXICOWANDERER wrote:
    The 100F day I see 39F on the door shelf of a gas refrigerator is the day I'll change my mind.
    Hhhhuuuuh?
    It's been a long time since we were camped or drove during a 100F day, but I THINK our RV's Norcold could hack it - especially if I bump it's slide switch to "5" - instead of the "3" setting that we normally set it at. In Death Valley our stuff stayed cool.
    Ya gotta have good ventilation, though, with a gas box in high temps. Perhaps many installations compromise ventilation too much?
  • Hi Phil,
    I've had to use extra measures to get my absorption fridge to work well. That included a mask at the top of the "chimney" with twin computer fans controlled by a thermostat. When they were new the rpms were the same, but now they "throb". Even then, I had to add a dual fan that hangs from the fins. That let me get to 3 out of 5 when it is not too hot out. The baffles are in the "right" place.
    I really it depends on the individual fridge.
  • Yes, I suspect that the baffles may be improperly placed or not there at all. had the same problem with one fan running slower than the other and had a slow throb. Then the throb went away as one fan quit and then we really had the heating problems. A 12" 120VAC fan blowing in the lower vent at least has us too borderline temperatures in the fridge. At the moment, 7:20 PM local time the outside air temperature is 27C, 80F. It was probably up to the low to mid 30s during the day.
    I'm still waiting for a couple of 4" 12VDC computer fans, then I'll ask for advice on where and how to place them. I'm not about to pull the fridge down here.
    I think I'll try to post a couple of photos of down the back of the fridge and see if Doug responds.
