DrewE
Dec 23, 2017Explorer III
I think your installer did things correctly.
Some inverters have a transfer switch built into them; yours may be one. In that case, when you're plugged into shore power, the inverter is not actually inverting but only passing through the shore power.
Even if it is running, so long as your converter is capable of supplying sufficient power to both run the fridge and charge the battery, you shouldn't need to worry about the batteries any more than previously when in storage. They aren't really being used; they're just sitting there floating.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
