wolfe10
Dec 23, 2017Explorer
As I posted on the other site where you asked, your Magnum inverter has a built in transfer switch.
So, when on either shore power or generator, it is not "inverting"/using battery power to supply the everything downstream of the inverter. It is merely passing through the power it gets and also charging the batteries (it does both).
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
