Just a quick tidbit of "stuff" I found inside and above fridge compartment. To fully explain, in the motorhome a large 12 volt fuse center is directly above and my main 120 volt circuit center is directly to the side. Anyways I found a bundle of extra wires including a 20 amp extra circuit already with a breaker, (un labeled spot on my main panel) but noted in panel manual as being a future. There is two or three additional 12 volt circuits bundled, an extra RG-6 cable run to the front and one other cable I haven't ID'ed yet. Amazing what you find when your not looking. :-)
