wa8yxm
Jun 12, 2013Explorer III
The short version.. Generators can be fueled by Diesel, Gasoline or Propane. Many installed generators in trailers are propane powered, but they suck a LOT of propane so that might not be the best option. I have seen some gasoline installed.
A portable (most are gasoline) is likely your best choice, The INVERTER types are very quite. in fact at a rally I was standing close enough to a Yahama running no-load to feel the exhaust against my leg and the 1200 watt I could not h ear, the 2400 I could, but I had to listen close for it (Trained to do that king of thing) I did not have to raise my voice over the noise till the thing topped 66% load. (800 watts in this case)
Honda is also good, then there are some made in china brands, Most are good but finding service may be harder to obtain if needed.
If you do not use air conditioning, SOLAR can provide a lot of 12vdc, and is absolutely silent.
Finally we have the open frame "Contractor" generators.. Low cost but .. They really need to include ear plugs with the generator.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
