NinerBikes's avatar
NinerBikes
Rethinking my 120w portable solar power panel.
After doing some more testing of voltage on my Wal Not so Smart Group 24 DC battery and my Solar Blvd 120W portable solar panel kit for my 21 foot travel trailer, as well as doing a lot more reading after getting my feet wet, I've come to a different conclusion as to getting far better results.
First off, the PWM module provided with the portable solar panel, while good, is not adjustable for voltage output. Due to DC line voltage losses, 14.4V at the charge controller output is not 14.4 volts at the other end of the 5 meter run of line that they give you in the kit, more like around 14.15. It's programmed and set up more as a power source, not a Golf Cart Battery charge controller, which is really what I need from a solar panel charge controller.
Secondly, since I will at a later time be going with a Trojan battery (s) of sorts that really requires about 14.8 to 15.0V to really get the battery charged to a true 100% recharge, not 90%, this will require a couple of changes.
Most importantly will be that the charge controller needs to be located really close to the location of the battery, but not close enough to be exposed to the corrosive out gassing fumes it generates while charging. I learned this from VW when they mounted their fuse boxes on top of the battery vents, where corrosive damage was done to the fuse blocks and wiring on my MK 4 VW jetta TDI diesel. Really, really dumb move, VW.
I will use 8 gauge strand wire, probably less than a 3 foot run, to handle the first 7.5 amps, as well as allowing for a potential additional panel, from a 20 amp adjustable PWM Charge Controller.
Secondly, I will wire no more than 15 feet from the panel to the PWM charge controller box, the panel needing the ability to track or follow the sun with 2 or 3 adjustments during the day to make the most from 9AM to 3 or 4PM daily. The voltage loss from panel to Charge controller from wire gauge is not as critical as that from charge controller to battery, so keeping the last run of wire thick and short from controller to battery is the critical consideration in this set up.. keep that loss to under 1%, no matter how much the short thick strands of copper wire cost for heavy gauge wire. Over engineer in that one area.
Thirdly and most importantly will be the ability to program and adjust the PWM Charge controller to 14.8 to 15.0V charge input at the battery, not at the charge controller, because that's what really matters when you want to top off charge a Trojan to a true 100% with solar panels on a regular basis. I realize there may be cloudy days that get the battery not completely topped off, however, I'd like enough panel power such that a 50% discharge of 150 Ah to 225 Ah is pretty much recoverable to a full charge in 2 consecutive days of sunshine. I think my daily Amp hour usage will run from 30 to 45 Amp Hours, my parasitic daily losses calc out to about 17-20 Amp hours with refrig and CO sensors. All my lights have been changed out to 48 SMD 3624 3000k flat panel LED's that draw about 5 watts each or about .42 Ah. TV draws about 2.7 Amps, when I watch it and Chromebook about 3 amp when on and charging, and it will charge in about 2 hours,less when turned off.
I believe if I address these three critical areas with a portable solar panel kit, override a standard 14.4V max charge set up with + .6V to 15.0. V at the battery terminals at peak output time of day, temperature corrected, should keep my Trojan batteries living long healthy lives.
I do plan to wipe off the solar panels when dusty or dirty or wet, to keep electrical generation in tip top shape, so as to allow my generator to save as much gas and noise as possible from my fellow campers and boondockers. Sorry if I sound so "green" and anything but Republican, I want to try to be as non intrusive with the wildlife as possible while still having some mobile comforts of home while fly fishing.
Keeping it portable, and using the KISS system was a good start, but reading here, and rereading and reading, and asking questions and PMing has helped me refine what works most cost effectively and best for me. I now probably have way more generators than I need, sitting around.
To everyone that took the time to post up a response, post an important link or send me a PM, I am forever grateful. I am a slow learner, this time it didn't cost me too much.
Probably one of the most valuable links I've read, written from a non biased, non agenda POV that confirmed a lot of the loose ends I've put together with my readings here. Don't run your solar panel and your generator at the same time, keep their charging isolated.
HandyBob and solar panel design basics.
  • Your on the right track on thoughts.
    First thing I'd do is as you described: Take the controller off the panel and mount it in the trailer near the battery and connect to the battery with some #12 or #10 wire. Keep it down to a few feet.
    Especially with a PWM controller this works well. Been there, done some experiements with my first PWM controller.
    What will result is that the battery will get the voltage at the output of the PWM contoller with almost no line loss (voltage drop). Yes, the line loss still exists, but it is "upstream" from the controller. What will happen is that as you add cable, your max output current move near Imp from near Isc. And even LONG cable runs with reasonable size cable will end up near Imp. And Imp and Isc are usually pretty close to each other on a % basis.
    In a post I did a month or so ago I did comparison of current loss with cabling and PWM controller. With my setup of 160 watts, with a few feet between the panel and controller I got 9.5A into the battery. Keeping the controller at the battery and adding 100ft (yes 100ft) of #10 cable,(well actually #7 on one leg, #10 on the other) current only dropped by 0.5A down to 9.0A and charge voltage stayed basically the same. Late summer, low sun, so couldn't get enough sun for full power.
    Panel current drop is because with the cable voltage IR drop, even though it may be small, you move the panel up the voltage curve in the region between Isc and Imp. So you go from something more than Imp with a very short cable to near Imp with longer cable. Once you get up the curve to Imp, current won't change much with "reasonable" additional cable voltage loss.
    If you want a nice long portable cable between the panel and the controller, get a 50ft 30A RV cord when they put them on sale. Then cut the ends off. Then take the green ground wire and since it isn't needed solder it at both ends to either the black or white. (same color at both ends) Cuts the voltage drop more. The two #10s in parallel become #7AWG)
    As I mentioned you should be able to run 100ft with this configuration and only suffer around 0.5A charging loss and still end up with the controller giving full output voltge.
    Don't worry about the 15', get that panel in the sun!!
    To connect to the controller, I put a 50A "anderson' connector on the trailer tongue and use anderson connectors on the ends of any extension cords. Makes a great low resistance quick and foolproof connector. At the panel end I put MC4 connectors on the panel wires and one end of the primary extension cord I use. Or, you could just put an anderson connector on the panel as well.
    I have two 25' cords and a 50' so I can pick and choose what is the best length to keep current up.
  • You shouldn't have that large of a voltage drop. Did you actually measure 14.40V at the charge controller and then 14.15V at the battery?
    How many panels do you have?
    Sal
  • The 15 ft panel to controller distance with a portable, aimable panel is a difficulty unless you can put the panel on the roof of the RV.
    You need the panel on the south side of the RV and even then you are limited to 180 degrees if that. The sun goes around more than that (46 degrees more on 21 June) so the trailer is blocking off the sun part of the time.
    It is even worse if you have the panel near one end of the trailer with awning and slide sticking out. You have to switch sides or ends where the panel is at some time during the day. Except you might need to put it in your neighbour's site to achieve this.
    It all gets complicated depending on your options at the site, but in general for a ground mounting and a 30ft long trailer, you need to get that panel much farther away from the trailer than 15 ft. I find 35ft is restrictive but doable where we camp.
    As mentioned , you can avoid all that trouble by placing your portable panel up on the roof so it can see all around, but now you have other issues to contend with. (contraption time! :) )
  • Hi niner,
    Any chance of upgrading the controller to one with battery voltage sense wires? Other than that "tweak" you plan sounds good.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
