Cstoliker
Aug 18, 2013Explorer
Reverse lights only work with parking/headlights on
98 Ford E Super duty Tioga. Inspection time I was checking the lights an noticed the reverse lights only come on when parking/headlights are on.
I re wired all the parking lights a while ago. The reverse lights have good ground 00.2-3 ohm from out side of bulb to frame. So it's not pulling the ground through a parking light bulb.
All other lights work normally. The reverse lights only get +12v at the socket when the transition is in reverse and the parking lights are on.
Is there something in the steering column that could be casing this?
