Golden_HVAC
Jul 12, 2014Explorer
Is your power cord end hot?
The reason I ask is a warm cord end indicates a loose connection, and it can have a 15 volt drop across the cord end. Mine did on a hot day while I ran the A/C. 13 amps X 15 volts is about 150 watts dropped across the plug end, heating it like a toaster element! Your voltage drop might not be as severe as mine was.
If the cord end is hot, or even a lot warmer than the air it is in, you might need a new cord end or new plug for the wall. Either is about $15 - $18, so might as well replace both.
Fred.
Fred.
