RoyB
Jun 14, 2013Explorer II
This is my battery bank setup using frame grounds at the battery bank. My converter/charger negative battery cable also is grounded to the trailer frame. I too am using 4AWG good quality marine grade battery cable.
When my converter/charger is operating I see a good 52-54AMPS DC Current being put back into the battery bank which tells me the frame ground connections are good.
My PD9260C is only about 5-feet away from the battery bank main switch but the 4AWG cable run to the DC Power Distribution Panel is around 12-feet away which also has the negative ground battery cable connection going to the trailer frame ground.
I did use the automotive method of tapping a hole into the trailer frame and uses a 5/16-inch thread tap. Then the Battery cable has the proper ring terminal with a STAR WASHER between the ring terminal and the frame ground to bite into the metal when tightned down. I always only use ONE BATTERY CABLE per frame ground connection.
The TAP BIT and Automotive Bolt and STAR washer is from PEPBOYS...
I might add that my install using this method since 2009 shows no signs of corrosion at the connection points.
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
