phemens
Jun 14, 2013Explorer
mena661 wrote:phemens wrote:I'm really sorry if it sounds like I'm nitpicking but I think doubling wiring smaller than 1/0 is against code. Someone can correct me if I'm wrong on that. I know people do it and IMO double #4 is MORE than adequate for 45 amps. Since you want to upgrade your inverter to the 3000W eventually, make that run a single 2/0 instead then you can double that up when you get the new inverter. Yeah, WAY overkill for now but just right for later.
Well, given that I might run the negative to the frame, that frees up a run of 4AWG - I could double up on the run for the positive feed, giving me 2x 4AWG to the distribution block...
Agreed, if I do put in an inverter, it will be right at the battery bank, so no worries. The run to the charger would not cover a new inverter.
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
