JRscooby
Aug 25, 2019Explorer II
Old-Biscuit wrote:
Jack trailer up by FRAME so wheels/suspension is fully extended
Wire up brake lines.....
Then lower back onto wheels
Check wiring for pitch spots/hung up spots
This is a given, do it with full extension. But if you run the shortest distance, from frame above the axle down to the brake, you have a chance of that wire catching anything as it is blowing in the wind. Follow the suspension, keep it tied tight except a little slack at the pivot points.
