oldwizard1's avatar
oldwizard1
rexhall vision 2003 m26
I have a inverter (1000 w) that when I turn it on has power to the outlets on inverter but I have no power on inside plugs. I have checked breakers etc. But still no power. I am really not sure if all the plugs or micro wave are all wired into the inverter or not. Also does anybody know where my converter is? I just aquired the motorhome from a widow who knows nothing about it. Thanx
  • I didn't say there was nothing plugged in, there are 2 cords that are plugged in and they go directly through the floor of the rig. Thanks all for the info.
  • Ex-Tech wrote:
    Most likely the inverter was not wired to any external loads so only the plugs on the inverter are powered.
    I worked at Rexhall in 2003 and we didn't offer a 1000 watt inverter as an option so you have one most likely installed by the previous owner or a dealer.
    Agree, My 2003 Vision does not have a factory installed inverter.
  • If there ain't nothing plugged into the sockets on the inverter, how could you expect to have power from it anywhere ?
  • Most likely the inverter was not wired to any external loads so only the plugs on the inverter are powered.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
