austinjenna's avatar
austinjenna
Rez fridge question
A blanket question, but on average those with residential fridges, how long will can it run on a single 12V deep cell battery?
I know there are variables here, size of battery, parasitic draws etc..but looking for just a generalized run time.
  • I started with two 12v 105 amp Hr batteries
    Which was adequate for over night as long as fully recharged each day
    Over the years that changed and in the end i was running over 500+ amphrs of Telco AGM batteries
    Start up surge was 900-1000 Watts, running use was just over 100 Watts , about 10 amps battery power into the inverter use
  • Don't forget that you will also have battery load from lights, water pump, TV and the biggie is the furnace.
    I have (4) six volt Costco golf cart @ 200aH each and during nights of 30-40° with the furnace at 60 I"m hitting 50% range depending on how heavy other usage is.
  • DallasSteve wrote:
    Drew: When you say 12 hours average does that consider only drawing the battery to about half charged? I've read that you should not go below half charge on the ordinary RV batteries.
    Yes, I was thinking you ought to avoid discharging much below half. Bear in mind that my estimate was only a rough, ballpark estimate, an order of magnitude number rather than a precise "expect exactly half a day" number. I was really more trying to suggest how one might go about making these sorts of useful but imprecise estimates quickly; having an idea of how to figure energy consumption vs. battery capacity is quite a useful skill for many things, not just fridges.
    Eight hours is probably a better general estimate than 12 hours, based on the valid points (and presumably firsthand experience) mentioned by other posters. I'm not sure I can think of many situations where 12 hours of fridge operation would be sufficient but altogether insufficient; so it seems to me for practical planning purposes either estimate is close enough. You can get an afternoon or an overnight, but not both. One battery might be (barely) adequate with a residential for travel between campsites with hookups, but nowhere near sufficient for any real boondocking or dry camping.
  • “I've read that you should not go below half charge on the ordinary RV batteries.”
    That’s the popular belief, Dallas, but in fact there isn’t that much difference between discharging to 50% and to 40% per Trojan, the horse’s mouth. See:
    https://www.trojanbattery.com/products/deep-cycle-flooded/solar_signature-line-flooded/
  • naturist wrote:
    DrewE wrote:
    Hours; maybe 12ish hours on average, if there is such a thing as average.
    This is a question that can be answered pretty well, at least well enough for back-of-the-envelope calculations, by comparing the usable energy storage of the battery with the energy consumption of a residential fridge. According to the Energy Star labels I've seen, a typical not huge fridge use around 1 kWh or a bit more per day on average (under their test conditions). A single marine/RV battery has maybe 50 Ah of usable charge, which multiplied by 12V yields 600 Wh or 0.6 kWh of energy.
    Well, except that (a) the usual battery on an RV is rated 75 or 80 AH, so the usable is more like 37.5 or 40 AH, and (b) that rating assumes a 20 hour discharge time, and will be less with a shorter discharge time, so that you are not going to get those 12 hours. Probably more like 8 or 9. Into the bargain, the compressor startup surge (as @oldman pointed out) will likely be beyond the single battery to supply; too many amps drawn at once.
    Correct.
    As Naturists points out and I will point out that a typical standard sized RV "12V battery" that you would get from a RV dealer lot will be of a Group 24 or Group 27 size.
    Group 24 might get you 70 Ahr and Group 27 might get you 80 Ahr of which you do not want to draw more than HALF of that capacity which nets you 35Ahr or 40 Ahr respectively.
    Oldman points out the startup surge, and he is correct, a single group 24 or 27 most likely will not have enough capacity to handle the startup surge current.
    My Res fridge has a running current of .80A at 120V, that roughly translates to 8A at 12V that the inverter will draw from the batteries.
    I measured the startup surge of 10A at 120V which translates to 100A at 12 that the inverter will draw from the batteries.
    The startup surge is in milliseconds but the battery must have enough capacity to not drop the voltage below 11V DC, otherwise the inverter will simply shut down due to too low of voltage.
    In reality you MUST have enough battery capacity to sustain the high startup surge and not drop the battery voltage below 11V after hrs and hrs of operation.
    one single Group 24 or 27 is not going to get you more than a few hrs due to the lack of surge capacity.
    You really need at a min of 200 Ahr (100Ahr usable) in order to get about 20-24 hrs of fridge operation before needing to recharge.
    To get that you will need FIVE group 27 12V batteries OR you could simply bite the bullet and buy two 6V Golf Cart batteries (wire in series plus to negative to get 12V).
    2 GC batteries wire in series would cost less than the five group 27 batteries. $70 (group 27) x 5 = $350 OR $90(GC batteries) x 2 = $180..
    Something else to consider, you NEED a ROBUST inverter, you are not going to make this work on a 600W or smaller inverter, they simply do not have the surge capacity. Some folks have been able to get way with 700W inverters but some have not. I personally suggest at a minimum go with a 1200W-1500W inverter, those tend to have enough surge capacity to reliably start the compressor.
    Additionally, you NEED to use a SHORT HEAVY GA WIRE to feed the 12V to the inverter. The shorter and heavier the wire the better chance you will be successful. I use 1/0 and kept mine under 10 ft total (5ft for pos and 5 ft for the neg).
    Cheap out and you will be redoing and redoing and be frustrated..
  • I'm also looking at a model with a residential refrigerator.
    naturist: Would 2 12V batteries probably handle the startup surge?
  • If you are going residential fridge then do it properly...four 6 volt batteries and adequate solar. Set yourself up for success, not failure.
  • Resi's have an initial startup surge, which I'm not sure a single battery will handle.
  • Hours; maybe 12ish hours on average, if there is such a thing as average.
