JimK-NY wrote:
MrWizard wrote:
Start up surge was 900-1000 Watts, running use was just over 100 Watts , about 10 amps battery power into the inverter use
I seems to me that the original question did not get a clear answer.  As above, a small residential refrigerator will run at roughly 100 watts.  That is roughly 10 amps @ 12 volts.  A typical RV battery will be in the range of roughly 70 AH with a usable capacity of 35 AH.  So a single battery will power the typical smallish residential refrigerator for about 3.5 hours.
The bottomline is a residential refrigerator only makes sense if you will have hookups all the time or you will need to run a generator frequently for long periods of time.  You also need to consider turning off the refrigerator when you are no hooked up, for example, when traveling for several hours.
I suppose the normal solution for boondockers is to run an RV refrigerator on propane when they don't have electric hookups.  The negative I've seen is that the RV refrigerators cost much more and - I forget; maybe there was another negative.  The model I like also has a residential refrigerator.  Most of the time I think I will have hookups, but sometimes I'd like to try boondocking sites without hookups.  So how could that work?
First, I plan to follow the weather and not be camping in 100 degree sun or freezing temps.  Second, I have a residential refrigerator behind me in this house and for the last 15 or 30 minutes it has been quiet.  The point is, they don't run 24/7.  And if you don't open the door a lot it can hold it's cold temps for several hours offline.  The other day they shut off power here (in Colombia) for 8 hours and our food in the fridge stayed pretty close to normal temps.
My thought is to also supplement with some solar and run the generator when necessary.  If I decide to boondock more often and longer then I may replace the original 2 12V batteries with 2 golf cart batteries, or whatever the best tech is.  Maybe add more solar or nuclear.   HA HA.  Sound like a plan?
