Techie's avatar
Techie
Rivet missing - Light Fixture
I noticed that one of my overhead fluorescent fixtures was dim, so thinking that a bulb had burned out I pulled the plastic cover and a bulb -- as well as some plastic bits -- fell out :h
Short story is that there are 4 rivets that attach the fixture sides to the base and one was missing. Also, the fixture was secured to the ceiling with only 3 rather than 4 possible screws. The combination allowed one tube to vibrate enough that the plastic socket covers for the tubes eventually failed.
I ended up replacing it entirely with LED's.
The long version of this is on my blog if you're interested.
1 Reply
  • Cool fix, Techie. Good that the old fixtures can still be used. No hassle of trying to find
    replacements the exact same size and shape as the old ones.
    I disagree with the company about the old ballasts though. They really should be removed,
    as you did. Who needs the mercury around, even in small amounts.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
