scooter4's avatar
scooter4
RM 2407 problem
My coach has on older Dometic RM 2807 Fridge. Yesterday I turned the unit on and it worked fine. Two Hrs later all the lights went out on the control board went blank and it stopped cooling. 12 and 110 V are present at the back of the fridge. Have no clue what the problem is. Anyone Scooter.
  • You may want to carry extra fuses. It blew for a reason.
    Make sure your drain tube is clear of the electrical components.
    Glad it was an easy fix, this time!
  • Thank you enblethen, that was an easy fix, blown fuse. great forum Scooter.
  • Check the 12 volt fuses on the circuit board.
    Check the cable connector going to the eyebrow on the circuit board.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
