Kait27
Jun 03, 2023Explorer
I ended up unhooking the igniter so that it no longer sparks. Fridge works fine on 120 V. Gas is off at the gas valve for fridge now. However when I did try on LP, ignitior still sparked when LP was on and lit, fridge cools good on LP.
Stove works fine.
No fault noted. Electric element works perfect. Actually too good. My fridge runs at 27deg and freezer at -4deg. Receptacle has 120v
Seems like two problems - Could this be a bad thermistor due to working too good.
My thought is the board may be bad. Because the fridge should prefer 120 when electric is present. Ingitor sparks when LP is lit and when 120v element is working too.
Stove works fine.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
