dougrainer
Jun 04, 2023Nomad
Kait27 wrote:
I ended up unhooking the igniter so that it no longer sparks. Fridge works fine on 120 V. Gas is off at the gas valve for fridge now. However when I did try on LP, ignitior still sparked when LP was on and lit, fridge cools good on LP.
Stove works fine.
No fault noted. Electric element works perfect. Actually too good. My fridge runs at 27deg and freezer at -4deg. Receptacle has 120v
Seems like two problems - Could this be a bad thermistor due to working too good.
My thought is the board may be bad. Because the fridge should prefer 120 when electric is present. Ingitor sparks when LP is lit and when 120v element is cooking too.
Yes, that would point to a bad board. Since the unit runs on 120 that means the Board is SEEING the 120 and should lock out the LP system. PLEASE respond with year model of RV. Doug
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
